Wind Shear
Wind is slowed down at the surface by trees and obstructions
Wind moving across the Earth's surface is slowed by obstructions like buildings, trees and similar and the wind velocity increases with altitude.
The wind shear can be expressed as
v / vo = (h / ho)α         (1)
v = the velocity at height h (m/s)
vo = the velocity at height ho (m/s)
α = the wind shear exponent
The wind shear exponent varies with the terrain.
Terrain Wind Shear Exponent
- α -
Open water 0.1
Smooth, level, grass-covered 0.15
Row crops 0.2
Low bushes with a few trees 0.2
Heavy trees 0.25
Several buildings 0.25
Hilly, mountainous terrain 0.25
Example - Wind Velocity at a Terrain with Several Buildings
With Wind Shear Exponent 0.25 and wind velocity at level 10 m measured to 5 m/s -  wind velocity at level 40 m can be estimated by transforming (1) to
v = (h / ho)α vo         (1b)
Substituting with values
v = ((40 m) / (10 m))0.25 (5 m/s)
    = 7.1 m/s
About the EngineeringToolbox
