Vector Addition
Online vector calculator - add vectors with different magnitude and direction
In mechanics there are two kind of quantities
  • scalar quantities with magnitude - time, temperature, mass etc.
  • vector quantities with magnitude and direction - velocity, force etc.
When adding vector quantities both magnitude and direction are important. Common methods adding coplanar vectors (vectors acting in the same plane) are
  • the parallelogram law
  • the triangle rule
  • trigonometric calculation
The Parallelogram Law
vector addition parallelogram law
The procedure of "the parallelogram of vectors addition method" is
  • draw vector 1  using appropriate scale and in the direction of its action
  • from the tail of vector 1 draw vector 2 using the same scale in the direction of its action
  • complete the parallelogram by using vector 1 and 2 as sides of the parallelogram
  • the resulting vector is represented in both magnitude and direction by the diagonal of the parallelogram
The Triangle Rule
vector addition triangle rule
The procedure of "the triangle of vectors addition method" is
  • from the nose of the vector draw vector 2 using the same scale and in the direction of its action
  • the resulting vector is represented in both magnitude and direction by the vector drawn from the tail of vector 1 to the nose of vector 2
Trigonometric Calculation
vector addition cosine rule
The resulting vector of two coplanar vector can be calculated by trigonometry using "the cosine rule" for a non-right-angled triangle.
FR = [ F12 + F22 − 2 F1 F2 cos(180o - (α + β)) ]1/2         (1)
F = the vector quantity - force, velocity etc.
α + β = angle between vector 1 and 2
The angle between the vector and the resulting vector can be calculated using "the sine rule" for a non-right-angled triangle.
α = sin-1 [ Fsin(180o - (α + β)) / FR ]         (2)
α + β = the angle between vector 1 and 2 is known
Example - Calculating Vector Forces
A force 1 of magnitude 3 kN is acting in a direction 80o from a force 2 of magnitude 8 kN.
The resulting force can be calculated as
FR = [ (3 kN)2 + (8 kN)2 - 2 (5 kN)(8 kN) cos(180o - (80o)) ]1/2
    = 9 kN
The angle between vector 1 and the resulting vector can be calculated as
α = sin-1[ (3 kN) sin(180o - (80o)) / (9 kN) ]
    = 19.1o
The angle between vector 2 and the resulting vector can be calculated as
α = sin-1[ (8 kN) sin(180o - (80o)) / (9 kN) ]
    = 60.9o
Online Vector Calculator
The generic calculator below can used to add vectors for velocity, forces etc.
 Magnitude of vector 1 - F1
Magnitude of vector 2 - F2
angle between vector 1 and 2 (degrees)
About the EngineeringToolbox
