Custom Search
Secure the system and achieve equal wear by alternate pumps in parallel
Maximum designed pump efficiency
Recommended flow velocity for the pump suction side
Cavitation may occur in fluid flow systems where local static pressure is below the vapor pressure
Centrifugal pumps characteristics - speed torque curve
An introduction to Centrifugal Pumps
Centrifugal pumps and minimum continuous flow
Centrifugal pumps design and dimensions standards
When a liquid flow through a pump, hydrodynamic losses depends on fluid viscosity
Selecting between Centrifugal Pumps and Positive Displacement Pumps
High temperatures and danger of impeller cavitation is the major challenge of condensate pumping
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa
Adapting pump capacities to process demand
An introduction to dynamic, absolute and kinematic viscosity and how to convert between CentiStokes (cSt), CentiPoises (cP), Saybolt Universal Seconds (SSU), degree Engler and more
The equation of mechanical energy in terms of Energy per Unit Mass, Energy per Unit Volume and Energy per Unit Weight involving head
Convert between volume flow units - gpm, liter/sec, cfm, m3/h - online flow unit converter
The energy equation can be used to calculate the actual head rise in a pump or fan
NEMA Frame Assignments
A definition and an introduction to Net Positive Suction Head - NPSH
An introduction tutorial to the basic operating principles of positive displacement pumps
The power gained by fluid from operating pumps or fans
Convert between common pressure units like Pa, bar, atmosphere, pound square feet, psi and more
Converting between common units for pressure and head - lb/in2, atm, inches mercury, bars, Pa and more ..
Turbo machines affinity laws are used to calculate volume capacity, head or power consumption in centrifugal pumps when changing speed - rpm - or wheel diameters
Calculate pump hydraulic and shaft power?
Overall pump and fan efficiency is the ratio - power actually gained by the fluid - to shaft power supplied
Recommended flow velocity required on the delivery side of the pump in systems with boiling liquids
Recommended flow velocity required for light oil systems on the delivery side of the pump
Horsepower requirements pumping water
Specific Suction Speed may be used to determine what general pump design to use for maximum efficiency
For pumps in serial - add heads, for pumps in parallel - add flowrates
Comparing pumps, compressors, blowers and fans
Definition of British Horse Power for pumps, fans and turbines - how to convert to other common units
Normal flow velocities on the delivery side of the pump in viscous systems
Centrifugal pumps and maximum - or shut-off - head
Specific speed may be determined independent of the pump size
Specific work of pumps, fans, compressors and turbines
Characteristics of stable and unstable centrifugal pumps
Static pressure and pressure head
Recommended water flow velocity on suction side of pump
Pump suction head as affected by altitude
To select a proper pump for a particular application it is necessary to utilize the system curve and the pump performance curve
Saturation pressure - exerted by escaping molecules
A converting table between viscosity units like Centiposes, milliPascal, CentiStokes and SSU
Recommended suction flow velocity of viscous fluids
Calculate temperature rise in pumps
Required flow velocities in water transport systems - on the delivery side of the pump
Calculate Pressure Head, Total Dynamic Head, Bowl Horsepower, Total Trust acting on Driver Thrust Bearing, Field Head, Power Loss due to Shafting, Power Loss in Thrust Bearings, Motor Load, Field Efficiency, Input Horsepower (Power Supplied to Driver) and Shaft Elongation
Costs pumping water
Custom Search
