Custom Search
The pressure in a fluid is defined as
"the normal force per unit area exerted on a imaginary or real plane surface in a fluid or a gas"
The equation for pressure can expressed as:
p = F / A (1)
p = pressure [lb/in2 (psi) or lb/ft2 (psf), N/m2 or kg/ms2 (Pa)]
F = force [1), N]
A = area [in2 or ft2, m2]
1) In the English Engineering System special care must be taken for the force unit. The basic unit for mass is the pound mass (lbm) and the unit for the force is the pound (lb) or pound force (lbf).
The absolute pressure - pabs - is measured relative to the absolute zero pressure - the pressure that would occur at absolute vacuum. All calculation involving the gas laws requires pressure (and temperature) to be in absolute units.
A gauge is often used to measure the pressure difference between a system and the surrounding atmosphere. This pressure is often called the gauge pressure and can be expressed as
pg = ps - patm (2)
pg = gauge pressure
ps = system pressure
patm = atmospheric pressure
Atmospheric pressure is pressure in the surrounding air at - or "close" to - the surface of the earth. The atmospheric pressure vary with temperature and altitude above sea level.
Standard Atmospheric Pressure (atm) is used as a reference for gas densities and volumes. The Standard Atmospheric Pressure is defined at sea-level at 273oK (0oC) and is 1.01325 bar or 101325 Pa (absolute). The temperature of 293oK (20oC) is also used.
In imperial units the Standard Atmospheric Pressure is 14.696 psi.
Since 1 Pa is a small pressure unit, the unit hectoPascal (hPa) is widely used, especially in meteorology. The unit kiloPascal (kPa) is commonly used design of technical applications like HVAC systems, piping systems and similar.
A torr (torr) is named after Torricelli and is the pressure produced by a column of mercury 1 mm high - equals to 1 / 760th of an atmosphere.
Pounds per square inch (psi) was common in U.K. but has now been replaced in almost every country except in the U.S. by the SI units. Since atmospheric pressure is 14.696 psi - a column of air on a area of one square inch area from the Earth's surface to the space - weights 14.696 pounds.
The bar (bar) is common in the industry. One bar is 100,000 Pa, and for most practical purposes can be approximated to one atmosphere even if
1 Bar = 0.9869 atm
There are 1,000 millibar (mbar) in one bar, a unit common in meteorology.
1 millibar = 0.001 bar = 0.750 torr = 100 Pa
The calculator below can used to convert between some common pressure units:
Custom Search
