Minor Loss in Pipe or Duct Components
Minor loss, pressure or head loss in pipe, tube and duct system components
Losses occur in straight pipes and ducts as major loss and in system components as minor loss. Components as valves, bends, tees add head loss common termed as minor loss to the fluid flow system.
The minor loss can be significant compared to the major loss - in fact when a valve is closed or nearly closed the minor loss is infinite. For an open valve the minor loss may often be neglected (a full bore ball valve).
Minor Loss
Pressure drops and minor loss in components correlates with the dynamic pressure and the minor loss can be expressed as
ploss = ξ 1/2 ρ v2         (1)
or
hloss = ξ v2/ 2 g         (2)
ξ = minor loss coefficient
ploss = pressure loss (Pa (N/m2), psf (lb/ft2))
ρ = density (kg/m3, slugs/ft3)
v = flow velocity (m/s, ft/s)
hloss = head loss (m, ft)
g = acceleration of gravity (m/s2, ft/s2)
  • 1 psf = 0.00694 psi (lb/in2)
The minor loss coefficient - ξ - ranges values from 0 and upwards. For ξ = 0 the minor loss is zero and for ξ = 1 the minor loss is equal to the dynamic pressure or head. The minor loss coefficient can also be greater than 1 for some components.
Minor Loss Coefficient
The minor loss coefficient can be expressed as:
ξ = ploss / (1/2 ρ v2)         (3)
or
ξ = hloss / (v2/ 2 g)         (4)
The minor losses in components depends primarily on the geometrical construction of the component and the impact the construction has on the fluid flow due to change in velocity and cross flow fluid accelerations.
The fluid properties - in general expressed with the Reynolds number - also impact the minor loss.
The head loss information about components is given in dimensionless form and the information is based on experiments.
Equivalent Length
The minor loss can be converted to a length equivalent to the length of pipe or tube that would give the same pressure or head loss.
Head loss can be expressed as:
hloss = λ (leq / dh) (v2/ 2 g)         (5)
λ = friction coefficient
leq = equivalent length of pipe or duct (m, ft)
dh = hydraulic diameter related to the pipe or tube with the component (m, ft)
Equivalent length can also be expressed as:
leq = ξ dh / λ         (6)
The Total Head Loss of the pipe, tube or duct system, is the same as that produced in a straight pipe or duct whose length is equal to the pipes of the original systems - plus the sum of the equivalent lengths of all the components in the system.
About the EngineeringToolbox
