Latent Heat Flow
Latent heat is the heat, when supplied to or removed from air, results in a change of moisture content - the temperature of the air is not changed
English (Imperial) units
The latent heat flow can be expressed in English (Imperial) units as
Ql = 60 hwe ρ q Δx         (1)
Ql = latent heat flow (Btu/hr)
hwe = 1060 - latent heat of vaporization of water (Btu/lb)
ρ = 0.075 - air density at standard conditions (lb/ft3)
q = measured air flow (ft3/min)
Δx = humidity ratio difference (lb water/lb dry air)
SI-Units
The latent heat flow can be expressed in SI-units (metric) as
Ql = hwe ρ q Δx / 3600         (2)
Ql = latent heat flow (kW)
hwe = 2465.56 - latent heat of vaporization of water (kJ/kg)
ρ = 1.202 - air density at standard conditions (kg/m3)
q = air flow (m3/hr)
Δx = humidity ratio difference (kg water/kg dry air)
About the EngineeringToolbox
