Hydropower
Water - power, head and flow rate
Online Hydropower Calculator
The calculator below can be used to calculate available hydroelectricity.
Density (kg/m3)
Efficiency
Volume flow (m3/s)
Head (m)
The theoretically power available from falling water can be expressed as
Pth = ρ q g h         (1)
Pth = power theoretically available (W)
ρ = density (kg/m3) (~ 1000 kg/m3 for water)
q = water flow (m3/s)
h = falling height, head (m)
hydropower, volume flow, head and power generation
Due to energy loss the practically available power will be less than the theoretically power. Practically available power can be expressed as
P = 1000 μ q g h         (2)
P = power available (W)
μ = efficiency (in general ranging 0.75 to 0.95)
Equation (2) can be simplified to express practically available hydropower in kW
P ~ 10 μ q h (kW)
About the EngineeringToolbox
