Custom Search
Air Conditioning systems - heating, cooling and dehumidification of indoor air for thermal comfort
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more
Noise is usually defined as unwanted sound - noise, noise generation, silencers and attenuation in HVAC systems
Systems for ventilation and air handling - air change rates, ducts and pressure drops, charts and diagrams and more
A procedure for acoustic noise calculation of ventilation systems
Air flow and required duct area
Calculating sensible and latent heat from persons, lights, electric equipment, machines, evaporation from water surfaces, polluting fluids and miscellaneous loads
Principles of dehumidifying - cooling, adsorption or absorption
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more
Exhaust and outlet temperatures for some common fuels - natural gas, liquefied petroleum, diesel and more
Higher calorific values for some common fuels - coke, oil, wood, hydrogen and others
The ignition point for some common fuels and chemicals - butane, coke, hydrogen, petroleum and more
Draw HVAC diagrams - Online with Google Docs
Definition of some common HVAC industry terms - absolute humidity, pressure, temperature and more
Tutorial to heat, work and energy - essentials as specific heat and specific heat capacity
The amount of vapor - kg per cubic meter - in humid air
Joists and maximum size of ducts and pipes
Moisture flows from one side of a wall or roof if the vapor partial pressure is higher on one side than the other
Natural gas consumption in common equipment - boiling pans, ovens, cookers, kettles and more
Stable and efficient combustion conditions require correct mixtures of fuels and oxygen
Outdoor design temperature and relative humidity in US states and cities - summer and winter
Custom Search
