Humidity Ratio of Air
Humidity ratio (GPP) is the ratio between actual mass of water vapor present in moist air - to the mass of dry air
Humidity ratio can be expressed by mass of water or by the vapor partial pressure in the moist air.
Humidity Ratio by Mass
Humidity ratio can be expressed as the ratio between the actual mass of water vapor present in moist air - to the mass of the dry air. Humidity ratio is normally expressed in kilogram or pounds of water vapor per kilogram or pounds of dry air.
Humidity ratio expressed by mass:
x = mw / ma (1)
x = humidity ratio (kgwater/kgair, lbwater/lbdry_air)
mw = mass of water vapor (kg, lb)
ma = mass of dry air (kg, lb)
Humidity Ratio by Vapor Partial Pressure
Humidity ratio can also be expressed with the partial pressure of water vapor:
x = 0.62198 pw / (pa - pw) (2)
pw = partial pressure of water vapor in moist air (Pa, psi)
pa = atmospheric pressure of moist air (Pa, psi)
The maximum amount of water vapor in the air is achieved when pw = pws the saturation pressure of water vapor at the actual temperature. (2) can be modified to:
xs = 0.62198 pws / (pa - pws) (3)
xs = specific humidity at saturation (kgwater/kgair, lbwater/lbdry_air)
Since the water vapor pressure is small regarding to the atmospheric pressure, the relation between the humidity ratio and the saturation pressure is almost linear.
Maximum specific humidity at some common temperatures:
| Temperature (oC) | Saturation Pressure of Water Vapor (Pa) | Maximum Humidity Ratio(kgw/kga) |
| 0 | 609.9 | 0.003767 |
| 5 | 870 | 0.005387 |
| 10 | 1225 | 0.007612 |
| 15 | 1701 | 0.01062 |
| 20 | 2333 | 0.014659 |
| 25 | 3130 | 0.019826 |
| 30 | 4234 | 0.027125 |
Note that the saturation pressure of water vapor, - and the maximum humidity ratio, increases dramatically with the air temperature. This important for the capacity of drying processes.
Example - Humidity Ratio of Moist Air
The specific humidity for saturated humid air at 20oC with water vapor partial pressure 2333 Pa at atmospheric pressure of 101325 Pa (1013 mbar, 760 mmHg) can be calculated as:
x = 0.62198 (2333 Pa) / ((101325 Pa) - (2333 Pa))
= 0.0147 (kg/kg)
= 14.7 (g/kg)
- Air Psychrometrics - The study of moist and humid air - air condition - psychrometric charts, Mollier diagrams, air temperature, absolute and relative humidity, moisture content and more .
- Absolute Humidity of Air - Humidity - or moist - is the water vapor present in air. Commonly used terms are Absolute, Specific and Relative Humidity
- Air Humidifying with Steam - Imperial Units - Amount of vapor (lb/h in 100 cfm) in humid air
- Air Required to Remove Moisture - Required air flow to remove moisture from a room
- Cooling and Dehumidifying Air - Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling
- Density of Dry Air, Water Vapor and Moist Humid Air - Calculate the density of dry air, water vapor or the mixture of air and water vapor - moist or humid air
- Drying Force of Air - The Drying Force of air may be expressed as the moisture holding capacity of the air and the evaporation capacity from a water surface to the air
- Enthalpy of Moist and Humid Air - The enthalpy of moist and humid air consist of sensible heat and latent heat - enthalpy is used to calculate cooling and heating processes
- Evaporation from Water Surfaces - The amount of evaporated water from a water surfaces - like swimming pools or an open tanks - depends on the temperature in the water and in the air, and the humidity and velocity of the air above the surface - online calculator
- Great Sensible Heat Factor - GSHF - The Great Sensible Heat Factor is the ratio between the sensible and total heat for a cooling coil
- Latent Heat Flow - Latent heat is the heat, when supplied to or removed from air, results in a change of moisture content - the temperature of the air is not changed
- Mixing Humid Air - Calculating enthalpy, heat, temperature and specific humidity in mixing humid air
- Moist Air and Degree of Saturation - The ratio of humidity ratio of moist air to humidity ratio of saturated moist air - the Degree of Saturation
- Psychrometric Terms - Dry Bulb and Wet Bulb Temperature, Specific Volume, Relative Humidity, Enthalpy and more ..
- Recommended Relative Humidity - Recommended relative humidity level
- Recommended Relative Humidity in Production and Process Environments - Recommended Relative Humidity - RH - in production and process environments like libraries, breweries, storages and more
- Relative Humidity of Air - The relative humidity of air can be expressed by partial vapor and air pressure - density of the vapor and air - or by the actual mass of the vapor and air
- Specific Volume of Moist Air - Specific volume is defined as the total volume of humid air per mass unit of dry air
- The relationship between Specific and Relative Humidity of Air - Calculating specific humidity of moist air knowing relative humidity, water vapor and air density
- Water Saturation Pressure - Water saturation pressure at temperatures ranging 0 - 100 oC and 32 - 700 oF - Imperial and SI Units
