Custom Search
Heat Removed by Air
Heat removed with air - dry and wet bulb temperature
The wet bulb temperature is a measure of total heat in mixtures of vapor and dry air - moist air.
If the initial and final wet bulb temperatures in heating or cooling processes are known - the heat transported by the air in the processes can be calculated with the charts below.
Heat Transported by Air - kJ per kg
heat removed by air - wet dry bulb temperature - kJ
Example - Heat removed with moist air
If air with a initial wet bulb temperature of 30oC (green line) is cooled down to 10oC - aprox. 70 kJ of heat is removed.
Heat Transported by Air - kJ per m3
Heat Transported by Air - Btu per lb
heat removed by air - wet dry bulb temperature - Btu
Heat Transported by Air - Btu per Cu. Ft.
heat removed by air - wet dry bulb temperature - Btu per cubic feet
  • Air Psychrometrics - The study of moist and humid air - air condition - psychrometric charts, Mollier diagrams, air temperature, absolute and relative humidity, moisture content and more .
Engineering News
Engineering Standards
