Fail Closed (FC)
A control valve which should go to closed position on control signal or air failure would be labeled FC
A control valve which should go to closed position on control signal failure should be labeled FC - Fail Closed. The control signal may be pneumatic, hydraulic or electric.
About the EngineeringToolbox
