Custom Search
ANSI Y1.1-1972
Conforming abbreviations according IEC
Elevation above sea level - in feet and meter - with barometric and atmospheric pressure - inches mercury, psia, kg/cm2 and kPa
Altitude and air temperature and air density
Cooling systems capacities and antifreeze required
Fluid and weight - ounce, drachms, grains, scruples ..
Heating temperature of shrink-fits
Compensating barometers for elevation
Relation between barometric pressure (inches water) and pressure in psi and psf
The Beaufort description and observation of wind and wind velocity
Common letters used in blueprint drawings
Board Foot - the volume measurement of lumber
Convert builder's measurements to surveyor's measurements
Typical building tolerances
Before products are sold within the European - EU - market, they have to be
Construction Specifications Institute's 2004 Master-Format Edition
Chemicals and trade names
Comparing European, UK, US and others clothing, shoes, shirts and sweaters sizes
Calculate concrete volume
Estimating concrete required to concrete columns
Estimate amount of concrete for footing
Estimating concrete walls
Π constants
e constants
Common engineering and construction contracts
Minutes to descimal hours
Determining conveyor capacities
Load and required power
Maximum conveyor slopes for various materials
Convert common cooking liquid and dry measure volumes to US and metric values
Convert between liquid volumes commonly used for cooking
Decibel is a logarithmic unit used to describe the ratio of the signal level - power, sound pressure, voltage, intensity, etc.
Design for Assembly Index
Standard layouts of drawing sheets
Standard metric sizes of drawing sheets
Hardwood and softwood drill speed chart
Driving distances between some major European cities
Tipping angles - common materials as ashes, sand, earth, shingles ...
Critical temperatures and concentration parameters for some common substances as coal, zinc, uranium and more
Effects of low-frequency vibration on building constructions
Power consumption and running time for commonly used electrical equipment
An introduction to the electrochemical series and corrosion of metals
Speed of sound, temperature and pressure at various elevations
Oil viscosity vs. temperature
Bricks - quantity and mortar required
Concrete volume per sq. ft. of slab
Calculating excavation slope
Factors of Safety - FOS - are important in engineering design
Wood Screws, Machine Screws, Sheet Metal Screws, Self Drilling SMS and more
F-rating, T-rating and L-rating of firestopping systems
Friction theory and coefficients of friction for some common materials and materials combinations
Practical storage life of common frozen foods
Optimal temperature and humidity conditions for some common fruits and vegetables
Converting between common fuel consumption units - US MPG, Imperial MPG, l/nm, l/100 km and km/litre
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing
or Golden Mean
Aggregate cover area
Grease is a combination of oil and thickener
Hardwood dimensional lumber sizes
European hazardous areas classifications in zones, protection types, temperature codes and codes
North American hazardous locations classification in classes, divisions and groups
Used for printing and drawing papers
Decimal equivalents of eights, sixteenths, thirty-seconds and sixty-fourths of an inch
International standard atmosphere - ranging elevation -2000 to 30000 meters - pressure, temperature, density, viscosity, thermal conductivity and velocity of sound
Acceleration of gravity and degrees latitude
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa)
Specific gravity and charge - temperature and efficiency
Convert between units like meters, feet, inches, yards, kilometers and miles
Distance traveled and fuel consumption - liter per km
Building loads on foundations
Relation of machine processes to tolerance grades
Manila rope 3-strand. minimum breaking strength and safe load
Convert from mapping scales to length and areas
Concrete Masonry Unit Blocks - CMU - dimensions
ANSI/SO, DIN and JIS
Reinforcing bar - European metric dimensions
Typically available mild steel rounds
Miles per gallon fuel chart
ASTM Mortar Types
Allowable withdrawal load
Some numerical constants
Nylon rope 3-strand and 8-strand. minimum breaking strength and safe load
Temperature limits lubricating oils
Calculate mortgage payment with Annual Interest Rate, Number of Years and Amount Borrowed
Osmotic pressure of some food materials
US engineering drawing series based on ANSI/ASME Y14.1 Decimal inch drawing sheet size and format
ISO drawing sheets compared with U.S. and Canadian drawing sheets
The ISO 216 A, B and C drawing series - dimensions of regular, oversized and envelope sheets
Commonly used US architectural drawing sizes
Office paper sizes as Letter, Legal, Tabloid and more
Pasteurization methods and temperatures
When a material is stretched in one direction it tends to get thinner in the other two directions
Polyester Polyolefin dual fiber rope 3-strand - minimum breaking strength and safe load
Polyester rope 3-strand and 8-strand. minimum breaking strength and safe load
Polypropylene fiber rope 3-strand and 8 strand - minimum breaking strength and safe load
Calculate number of studs
Weight of rebar rods - size ranging 1/4
Roman numerals are combinations of seven letters
Run, Roof Slope, Gable Height and Gable Area
Weight calculator - roofing materials
Safe load for shackles
American National Standards Institutes schedule of safety colors marking physical hazards
Sandpaper - grit sizes
Scale of objects in a broader perspective
Vessel and cargo capacity
Commonly used United States Standard sieve numbers and openings
Load capacity of simply supported concrete slabs
Sisal rope 3-strand, minimum breaking strength and safe load
Converting slopes between degrees, gradients and grades
Rough Lumber, Surfaced Lumber (dressed), Worked Lumber, Shop and Factory Lumber and Yard Lumber
Commercial softwood lumber dimension chart - nominal and actual sizes
Soil or rock expansion - swell - after mining
Converting between speed and velocity units - m/s, km/h, knots, mph and ft/s
Speed plotted against time
Maximum fire sprinkler protection area
Typical weight of mild steel square bars
Calculate unit rise and run
Standard gages for wire and sheet - American, Birmingham, Washburn, Music, Stubs ..
Typically weight of mild steel flats
Steel plates size & weight - thickness range 3/16 - 10 inches - and metric units
Volume in stockpiles - cubic feet, yard, meter and decimeter
Calculating the stressed area in UN and UNR bolts
Lumber and surface finish abbreviations
U.S. mesh size and surface roughness
Different mechanical production methods and surface roughness
Volume of cylindrical (round) tanks - US. gallons per foot of dept or length
Tempering process of hardening steel
The Greek alphabet is essential when expressing formulas and technical language
Recommended thickness of concrete slabs
M Thread (metric ISO 724 thread) Standard in Europe
Lubrication effects on torque
High, moderate and low water demand
Calculate trench excavation
Weighing gold and silver
Rebar, U.S. imperial dimensions
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt
Machine Screw Diameters
Printable fastener tools series
Online UTM to Latitude Longitude converter
The ASTM E1557 UNIFORMAT II Standard
Height of trees commonly used in towns
Enhancing function - improving value
Speed (miles per hour), time (hours) and distance traveled (miles)
Speed (km per hour), time (hours) and distance traveled (km)
Tank volume per foot of depth
Water to cement ratio in concrete
Sandstone, Granite, Limestone, Marble and Slate
Wire rope 6-strand x 19 wire (6 x 19) - weight - minimum breaking strength and safe load
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and compressive strength
Shank diameters - pilot holes
Pilot holes, shank clearance holes and countersink diameter - hard wood and soft wood
Comparison of US and metric wrenches
An introduction to pH
Custom Search
