Custom Search
Maximum distance of various gauge two conductor copper wire
American Wire Gauge - AWG - and circular mils
Convert American Wire Gauge (AWG) to square mm cross sectional area
Maximum current - amps - through a 12V circuit in combination with size (AWG) and length of wire
Electrical motor data - nominal current, fuse, start ampere, contactor and circuit breaker of asynchronous motors
Current load and maximum wire length
Before products are sold within the European - EU - market, they have to be
The circular mil area - CM - is a unit denoting the cross-sectional size of a wire or cable
Capacitors and capacitance - charge and unit of charge
Energy stored and potential power generated from capacitors
Capacitors and parallel and series capacitance
Recommended copper wire gage and transformer size for single phase - 230 Volts - electrical motors
Recommended copper wire gage and transformer size for Three Phase - 230 & 460V - electrical motors
Light sources and color irradiation
Value and tolerance
Conductors and conductivity
Electrical conduit trade sizes, max distance between supports
Converting amperage between single phase (120, 240 and 480 Voltage) and three phase (240 and 480 Voltage)
Converting from NEMA enclosure classifications to IEC enclosure classifications
Gage, circular mils, electrical resistance and weight
Wire length versus wire size with max. 2% voltage drop
The most common used electrical formulas - Ohms Law and combinations
Temperature change when mass is electrical heated
Full load current - 460 Volts, 230 Volts and 115 Volts motors - single and 3-phase
Online electric motor calculator - calculate amps, hp and kVA
Calculating electric motor efficiency
NEMA electrical motor frame sizes
Indicating locked rotor code letters for electrical motors
NEMA - electrical motors efficiency ratings
Horsepower versus torque and motor velocity - rpm
Temperature and insulation classes
Direct-on-line Starters, Star-Delta Starters, Frequency Drives and Soft Starters
Heat gain from electrical motors to the surroundings
Change in electrical potential between two points
Definition of common electrical units as Ampere, Volt, Ohm, Siemens and more.
An introduction to the electrochemical series and corrosion of metals
Size of extension cords - full load rating 115 V
The velocity of 2, 4, 6 and 8 poles electrical motors at 50 Hz and 60 Hz
Current - Amps - in 120 and 240 Volt DC motors
Comparing IEC and NEMA torque classifications of electrical motors
The eight - S1 - S8 - IEC duty cycles of operating electrical motors
IP - Ingress Protection rating is used to specify the environmental protection - electrical enclosure - of electrical equipment
Electro Magnetic Field - EMF - induced into a circuit
Energy stored in the magnetic field
Kirchhoff's current and voltage laws
Indicating value of resistors by letter and digit code
Installed light power in some common types of buildings and rooms
Maximum current for copper and aluminum wire
Motor wiring data - NEMA Amps, Starter size, HMCP Size .. - motors ranging 1/2 - 500 HP
National Electrical Manufacturers Association
NEMA has established four different designs - A, B, C and D - for electrical induction motors
General description of NEMA electrical enclosures types
The NEMA enclosure standards of electrical motors
Insulation systems are rated by standard NEMA classifications to maximum allowable operating temperatures
Nema size contactors
The relationships between voltage, current and resistance
Calculate AWG, mil, mm, CM or square mm
Resistors connected in parallel
Output voltage from a potential divider
Power Factor definition for a three-phase electrical motor
Typical power wiring color codes
Electrical power is rated in Horsepower or Watts
Properties of rechargeable batteries or accumulators
Some common materials and relative permittivity
The reciprocal of electrical Resistance is called Conductance
Electrical resistance and resistivity
Resistivity, conductivity and temperature coefficients for some common materials as silver, gold, platinum, iron and more - Including a tutorial explanation of resistivity and conductivity
Preferred number series for resistors
Imperial Standard Wire Gauge for sheet metal and wire
Voltage and current
The service factor - SF - is a measure of periodically overload capacity at which a motor can operate without overload or damage
Single phase electrical power equations
The difference between the synchronous and asynchronous speed - also named rated speed - is "the slip"
The speed of operating electrical motors with loads, are lower than the motors synchronous speed (no load)
The speed at which an induction motor will operate depends on the input power frequency and the number of electrical magnetic poles in the motor
Synchronous and approximate full load speed of amplitude current (AC) induction motors
Electrical 3-phase equations
Full load amps - wire and conduit size
There are some common torques used to describe and classify electrical motors
Alternating voltage and induced e.m.f in an ideal transformer
A transient is a high voltage spike caused by external or internal transient sources
A variable-frequency drive develops heat loss during work. To avoid overheating it is often necessary to ventilate the location around the frequency-drive
Ohm's law and calculating voltage drop
The efficiency of an electrical polyphase motor decreases with increased voltage imbalance.
The common US wire gauges - AWG gauges
Apparent, True Applied and Reactive Power
Custom Search
