Custom Search
The density of air varies as the temperature and moisture content in the air varies. When the temperature increases the higher molecular motion results in an expansion of the volume and thus decreasing the density.
The density of a gas, either it is dry air, water vapor or a mixture of dry air and water vapor - moist or humid air, can be calculated on basis of the Ideal Gas Law.
The density of dry air can be expressed as:
ρa = 0.0035 pa / T (1)
ρa = density dry air (kg/m3)
pa = partial pressure of air (Pa, N/m2)
T = absolute dry bulb temperature (K)
The density of water vapor can be expressed as:
ρw = 0.0022 pw / T (2)
pw = partial pressure water vapor (Pa, N/m2)
ρw = density water vapor (kg/m3)
The amount of water vapor in air influences density. Water vapor is a relatively light gas compared to diatomic Oxygen and diatomic Nitrogen - the dominant components in air.
When water vapor content increases in the moist air the amount of Oxygen and Nitrogen decreases per unit volume and the density decreases because the mass is decreasing.
Based on the specific volume of moist air density can be expressed as:
ρ = 1 / v
= (p / Ra T) (1 + x) / (1 + x Rw / Ra) (3)
v = specific volume of moist air per mass unit of dry air and water vapor (m3/kg)
Ra = 286.9 - the individual gas constant air (J/kg K)
Rw = 461.5 - the individual gas constant water vapor (J/kg K)
x = specific humidity or humidity ratio (kg/kg)
p = pressure in the humid air (Pa)
Density of dry air can be expressed as:
ρda = p / Ra T (4)
ρda = density dry air (kg/m3)
Combining (4) and (3):
ρ = ρda (1 + x) / (1 + x Rw / Ra) (5)
The gas constant ratio between water vapor and air is
Rw / Ra = (461.5 J/kg K) / (286.9 J/kg K)
= 1.609
Inserting the ratio in (5):
ρ = ρda (1 + x) / (1 + 1.609 x ) (6)
Note! As we can see from (6) increased moisture content will reduce the density of the moist air - Dry air is more dense than moist air.
Custom Search
