Decibel
Decibel is a logarithmic unit used to describe the ratio of the signal level - power, sound pressure, voltage, intensity, etc.
Most signal systems - as sound power or sound intensity, human speech, sonar, microwaves, radio signals and fiber optics - can be described by
  • transmitting power
  • transmission path loss
  • receiver sensitivity
Transmitting power, path loss and receiver sensitivity are absolute power values - Watts in the SI system.
The Definition of Decibel
Decibel is a logarithmic unit used to describe the ratio of the signal level - power, sound pressure, voltage or intensity or several other things.
The decibel can be expressed as:
decibel = 10 log(P / Pref )         (1)
P = signal power (W)
Pref = reference power (W)
A decibel is one-tenth of a Bel - named after Alexander Graham Bell, the inventor of the telephone.
Note! Doubling the signal level increases the decibel with 3 dB (10 log (2)).
If we know the decibel value and the reference level, the absolute level can be calculated by transforming (1) to:
P = Pref 10(decibel / 10)         (2)
Example - Sound Intensity and Decibel
The difference in sound intensity of 10-8 watts/m2 and 10-4 watts/m2 (10,000 units) can be calculated in decibels as
ΔLI = 10 log( (10-4 watts/m2) / (10-12 watts/m2) ) - 10 log( ( 10-8 watts/m2) / ( 10-12 watts/m2) )
    = 40 dB
Increasing the sound intensity by a factor of
  • 10 raises its level by 10 dB
  • 100 raises its level by 20 dB
  • 1,000 raises its level by 30 dB
  • 10,000 raises its level by 40 dB and so on
About the EngineeringToolbox
