Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Cv Diagram Water Valves
Water valve Cv diagram
Kv Diagram Water Valves
Kv diagram for modulating water valves
Adding Kv or Cv values
Adding Kv or Cv when control valves are in series or parallel
Control Valve Sizing Calculator - Gases
An online control valve - Cv - calculator for gases
Control Valve Sizing Calculator for Liquids
Online control valve - Cv - calculator for liquids - flow, specific gravity and upstream pressure inputs calculates Cv
Control Valve Sizing Handbook
Masoneilan Control Valve Sizing Handbook - Valve flow characteristics, Cv formulas, materials of construction, body styles and elastomers
Control Valve Sizing for Steam Systems
Calculating steam control valves
Control Valves and Cavitation
Control valves and cavitation, application ratio and multi stage control valves
Control Valves and Flow Characteristics
The relationship between control valve capacity and stem traveling
Fail Closed (FC)
A control valve which should go to closed position on control signal or air failure would be labeled FC
Fail Last (FL)
A control valve which should stay put on control signal or air failure would be labeled FL
Fail Open (FO)
A control valve which should go to the open position on control signal or air failure should be labeled FO
Flow Coefficient - Cv - Formulas for Liquids, Steam and Gases - Online Calculators
The flow coefficient - Cv - is important for proper design of control valves
Flow Coefficient Cv and Flow Factor Kv
Comparing flow coefficient Cv with flow factor Kv
Flow Coefficients - Cv - and Flow Factors - Kv - of Straight Through Diaphragm Valves
Typical flow coefficients - Cv - and flow factors - Kv - of
Flow Coefficients - Cv - and Flow Factors - Kv - of Weir Diaphragm Valves
Typical flow coefficients - Cv - and flow factors - Kv - of weir diaphragm valves of
Gases - Specific Gravities
Specific gravity of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases
Leakage Classification of Control Valves
Classification of seat leakages through control valves
Metals and Corrosion Resistance
Common metals and their corrosion resistance to aggressive fluids as acids, bases and more
Normally Closed (NC)
The term Normally Closed
Normally Open (NO)
The term Normally Open
Safety Steam Valve Installation Guide
Guidelines to safety steam valve installation
Sizing and Selection Control Valves
Select and size the control valve that most closely matches the process requirements
Sizing and Selection of Butterfly Valves
Selecting and sizing butterfly valves for water applications
Steam Control Valves - Calculating Kv Values
Design of steam control valves and their Kv values
Valve Authority
Valve authority express the ratio between pressure drop across the control valve compared to the total pressure drop across the whole circuit
Water Control Valves - Calculating Kv Values
Design of water process control valves and their Kv values
