Beams and Columns
Deflection and stress, moment of inertia, section modulus and technical information of beams and columns
Aluminum Channels
Dimensions and static parameters of Aluminum Channels
Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units
American Standard Beams
American Standard Beams ASTM A6 - Imperial units
American Standard Steel Channels
Dimensions and static parameters of American Standard Steel Channels
American Wide Flange Beams
American Wide Flange Beams ASTM A6 in metric units
American Wide Flange Beams ASTM A6 in English units
Area Moment of Inertia
Second Moment of Inertia or Area Moment of Inertia
Area Moment of Inertia Converter
Conversion of Area Moment of Inertia
Beam Support Force Calculator
Calculate beams loads and support forces
Properties of British Universal Steel Columns and Beams
Density, Specific Weight and Specific Gravity
An introduction and definition of density, specific weight and specific gravity - formulas with examples
Force
Force, Newton's third Law and acceleration
HE-A Steel Beams
Properties of HE-A profile steel beams
HE-B Steel Beams
Properties of HE-B profile steel beams
HE-M Steel Beams
Properties of HE-M profile steel beams
Maximum Floor Joists Span
Douglas Fir and maximum span
Maximum Horizontal Roof Rafter Span
Moment of Section Conversions
Convert Moment of Section (Inertia) units
Normal Flange I Beams
Properties of normal flange I profile steel beams
Section Modulus Conversions
Convert Section Modulus
Square Hollow Structural Sections - HSS
Steel Angles
Dimensions and static parameters of steel angles with equal legs - metric units
Steel Angles
Dimensions and static parameters of steel angles with equal legs - imperial units
Steel Angles with Unequal Legs
Dimensions and static parameters of steel angles with unequal legs - imperial units
Dimensions and static parameters of steel angles with unequal legs - metric units
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns
Stress and Deflections in Beams
Beams and shafts - deflection and stress calculator
Wood Beams Strength
Bending and compression strength of wood beams
