Adding Kv or Cv values
Adding Kv or Cv when control valves are in series or parallel
Control Valves in Parallel
control valves in parallel
The resulting Kv or Cv if two valves are installed in parallel can be calculated as
Kvt = Kv1 + Kv2          (1)
Kvt = resulting Kv
Kv1 = Kv valve 1
Kv2 = Kv valve 2
Control Valves in Series
control valves series
The resulting Kv or Cv if two valves are installed in series can be calculated as
1 / (Kvt)2 =  1 / (Kv1)2 + 1 / (Kv2)2           (2)
About the EngineeringToolbox
